Jean Michel JarreNajnowsze wariactwo JMJ?
KamiXXX
Re: Najnowsze wariactwo JMJ?
Post #113372 autor: KamiXXX » 30 wrz 2016, 11:09
Pogłoski okazują się prawdą:
December 2nd 1976 saw the release of Oxygene 1, which I can say changed my life !
Today, for its 40th anniversary I can reveal that a brand new album, Oxygene 3 will be released on December 2nd 2016.
I don’t necessarily like anniversaries that much…But when I was recording Electronica, two years ago, I did a piece of music (today Oxygene 19) that made me think about what Oxygene could be if I was composing it today. Then I took the 40th anniversary of the first album as a deadline to push myself to see if I could compose this new chapter in six weeks, just like I did for the first one: probably to avoid thinking too much about, whether it was a good idea or not, and also to record everything in one go… The idea was not to copy the first album, but rather keeping the dogma of embarking listeners on a journey from beginning to end with different chapters, all linked to each other.
What made the first Oxygene so different at the time, is probably the minimalist aspect, and the fact that there are almost no drums, and I wanted to keep this approach, creating the groove mainly with the sequences and the structure of the melodies only, through an architecture of sounds.
When I did the first Oxygene in the vinyl days, I had a structure in mind divided in 2 parts, fitting the A&B sides of an album. This time I enjoyed doing the same: one side being darker, the other being brighter. So when I think of it today, Oxygene 3 has actually two sides…
I did the first Oxygene on an 8 track tape recorder with very few instruments, with no other choice than being minimalist. I tried to keep this minimalist approach for Oxygene 3. Some moments are built around one or two elements, like in the first volume.
It was important to me to keep the artwork for Oxygene 3 in line with the two previous albums…40 years ago too, I discovered Michel Granger’s visual universe and immediately felt a total adequacy with the music I was composing. Since then, the cover artwork became famous, like an ecological warning signal, dark and surreal, evoking both outer space and that of our vital living space: this image, for me, has become inseparable from the music.
I wanted the Oxygene 3 visual to remain in that same vein, and hence to re-visit Michel Granger’s original work, simply shifting «photographed-like» from another angle, which was exactly aligned with the approach I had to create this new chapter in music. To this end, I asked Michel Granger’s permission to perform a 3D model of his creation in order to change the angle of the visual, which he amicably accepted.
What an incredible journey Oxygene has been so far. I very much look forward to continuing the Oxygene story with all of you.
See you on the road,
Love
Jean-Michel Jarre
Oxygene 3 and the Triology Boxset will be out 02.12.2016. I may well play sometimes an excerpt of Oxygene 3 during the tour..
Źródło: https://www.facebook.com/jeanmicheljarre/posts/10154605753739096:0
Ulubieni wykonawcy: Depeche Mode, Tangerine Dream, Boards Of Canada, Autechre, Arcane
Post #113373 autor: Sublime » 30 wrz 2016, 12:37
JMJ to już chyba specjalnie robi śmietnik ze swojej dyskografii, nazywając to "Oxygene 3", a nie "14-20". Zresztą ten tekst jest pełen jakiś typowych marketingowych wstawek i zupełnych sprzeczności. Jeszcze gorszy jednak jest ten zachwyt "fanów", którzy są zachwyceni tym, jak to wspaniałomyślnie Jarre spróbuje zaprezentować Oxygene tak, jakby to on miał go w 2016 roku nagrać. Śmiech przez łzy.
jarre3
Post #113374 autor: jarre3 » 30 wrz 2016, 20:20
To jest wątek o 3 części Oxygene, czy o bólu dupska niejakiego Sublime, który co drugi post wylewa swoje żałosne żale??.
Najpierw osiągnij 10% tego co osiągnął w życiu JMJ a później dopiero go krytykuj. Typowe zachowanie wiejskiego polaczka ze słomą w butach i wybujałym ego.
Post #113376 autor: PM7 » 30 wrz 2016, 22:59
jarre3 pisze:Najpierw osiągnij 10% tego co osiągnął w życiu JMJ a później dopiero go krytykuj.
Poczytaj o teorii argumentacji zanim zaczniesz posługiwać się takimi nic nie wartymi argumentami.
Najtrudniejsze w powtórzeniu sukcesu Jarre'a jest ustalenie jak udało mu się wypromować płytę i sfinansować swoje pierwsze duże koncerty, oraz zdobyć te potrzebne środki. Cała reszta jest mało istotna, bo jego warsztat muzyczny zawsze był słaby.
jarre3 pisze:Typowe zachowanie wiejskiego polaczka ze słomą w butach i wybujałym ego.
Pewien nasz biskup powiedział kiedyś o czymś, że szanuje się to tylko dopóki niczego się w tym nie rozumie...
Post #113377 autor: Sublime » 30 wrz 2016, 23:05
jarre3 pisze:To jest wątek o 3 części Oxygene, czy o bólu dupska niejakiego Sublime, który co drugi post wylewa swoje żałosne żale??.
Czym innym jest krytyka, a czym innym zachowywanie się jak zwierzę. I to z wścieklizną. Czy jest na sali weterynarz? :wink:
seth
Post #113384 autor: seth » 02 paź 2016, 19:57
Ale jarre3 ma trochę racji, nikt nie zna Oxygene 3 (czy jak tam się będzie to wydawnictwo nazywać) więc pisanie o tym projekcie jako kolejnym wariactwie JMJ jest kompletnie nie zrozumiałe dla mnie. Jak post wyżej "czym innym jest krytyka..." itd. Może więc lepiej z krytyką wstrzymać się do momentu w którym zapoznacie się z w/w wydawnictwem? Bo krytykowanie samego pomysły nie jest krytyką tylko właśnie tym co napisał jarre3.
Post #113385 autor: PM7 » 02 paź 2016, 20:16
Ja się wstrzymuję do tego czasu, polemizuję jedynie z argumentacją która jest absurdalna.
Niemniej patrząc na to co Jarre robił przez ostatnich 20 lat, i na ten fragment: "to see if I could", nie spodziewam się niczego dobrego. Jarre nie zaprezentował nigdy czegoś ponad poziom Equinoxe czy Zoolook i raczej stacza się od tamtego czasu. Jeżeli on musiał w przypadku Oxygene 3 dopiero zobaczyć czy da sobie radę, to jest jasne że przez te wszystkie lata ani się nie uczył ani nie ćwiczył, więc są podstawy by spodziewać się sporego spadku formy.
musman76
Post #113386 autor: musman76 » 02 paź 2016, 20:22
Co do planowanego wydawnictwa Jarre'a, jestem podobnego zdania jak Seth - z domieszką obojętności, co najwyżej: chce, niech sobie wydaje, może posłucham na YouTube, kiedy się ukaże, najwyżej będzie słabe.
Post #113388 autor: Sublime » 03 paź 2016, 1:21
seth pisze:Ale jarre3 ma trochę racji, nikt nie zna Oxygene 3 (czy jak tam się będzie to wydawnictwo nazywać) więc pisanie o tym projekcie jako kolejnym wariactwie JMJ jest kompletnie nie zrozumiałe dla mnie. Jak post wyżej "czym innym jest krytyka..." itd. Może więc lepiej z krytyką wstrzymać się do momentu w którym zapoznacie się z w/w wydawnictwem? Bo krytykowanie samego pomysły nie jest krytyką tylko właśnie tym co napisał jarre3.
Ale to tak, jakby próbować się nabrać na żart słyszany już setki razy. Kolega PM7 wyjaśnia to jak trzeba. Prymitywny i absolutnie absurdalny argument typu "sam zrób lepiej, skoro taki z ciebie ignorant" raczej ośmiesza osobę, która go używa.
Post #113389 autor: Stefan » 03 paź 2016, 8:47
W zasadzie wszystko byłoby o.k. gdyby JMJ nie nazwał swego dzieła po raz kolejny "Oxygene".
Spory są zatem o nazwę. :yes:
seth
Post #113390 autor: seth » 03 paź 2016, 10:41
Ale wszystko jest OK. JMJ może nazwać kolejne wydawnictwo jak chce i nikomu nic do tego (oczywiście jeśli nie narusza praw autorskich osób trzecich). Nikt wam nie każe tego słuchać a tym bardziej kupować. W czym więc problem? Nie bardzo rozumiem tego "obrażania" się na twórców. Skoro chce to zrobić i może niech robi. Jeśli komuś się spodoba to dobrze, a jeśli nie to nic złego się nie stanie.
piotrasz
Post #113391 autor: piotrasz » 03 paź 2016, 12:47
seth pisze:Nie bardzo rozumiem tego "obrażania" się na twórców.
Jeśli ktoś kiedyś ustawił sobie poprzeczkę bardzo wysoko, a teraz nie jest w stanie nawet się do niej zbliżyć - to chyba jednak jest coś nie tak, jak być powinno. Wyobrażasz sobie, że np. znany i ceniony kompozytor muzyki poważnej zaczyna w pewnym momencie pisać dla branży disco-polo? Jakbyś wtedy zareagował? :wink:
Ps. Powyższe porównanie jest zupełnie przypadkowe i nie ma na celu "obrażania" się na JMJ. Jeśli jednak on sam uważa, że może dalej tworzyć, powinien mieć chyba odrobinę więcej szacunku do swoich pierwszych płyt...
"lepsze jest wrogiem dobrego"
Post #113393 autor: PM7 » 03 paź 2016, 14:00
Jarre ma oczywiście prawo robić ze swoimi wydawnictwami co chce, spór jest już tylko o to, na ile jego marketing jest wiarygodny. Z perspektywy kogoś kto zna historię jego twórczości i ma pojęcie o warsztacie muzycznym, wiarygodny to on nie jest. Jeżeli w świetle znanych faktów, Jarre choćby zbliży się do poziomu pierwszego Oxygene, to podziwiam trwałość jego układu nerwowego, bo z muzyką jest jak ze sportem: albo cały czas ćwiczysz, albo wypadasz z formy.
musman76
Post #113394 autor: musman76 » 03 paź 2016, 14:24
PM7 pisze:Jeżeli w świetle znanych faktów, Jarre choćby zbliży się do poziomu pierwszego Oxygene, to podziwiam trwałość jego układu nerwowego, bo z muzyką jest jak ze sportem: albo cały czas ćwiczysz, albo wypadasz z formy.
Da radę, przecież mówił kiedyś, że w dobrej formie utrzymuje się dzięki wódce Chopin; a pod takimi auspicjami musi być arcydzieło, tyle że wtedy, gdy wyjawił to magiczne źródło, widocznie jeszcze nie wchłonął wystarczająco dużo tej płynnej inspiracji.
A poważnie, też myślę, że argument "jak sam nie umiesz, to się nie odzywaj" do niczego nie prowadzi.
piotrasz pisze:Jeśli jednak on sam uważa, że może dalej tworzyć, powinien mieć chyba odrobinę więcej szacunku do swoich pierwszych płyt...
Ta kwestia co i rusz powraca w przypadku sław muzyki elektronicznej i nie tylko takiej. Dla samych tych płyt ani ich istniejących miłośników to, że autor tych nagrań rozmienia się na drobne, niewiele zmieni: płyty te będą tak samo dobre, jak były, choć trzeba przyznać, że nowy materiał może nie zachęcać pozostałych słuchaczy do zapoznania się z tym wcześniejszym i lepszym.
seth
Post #113395 autor: seth » 03 paź 2016, 14:37
Byłbym zdziwiony i tyle. To byłaby jego decyzja i nikomu nic do tego.
jman
Post #113396 autor: jman » 03 paź 2016, 21:15
1. Nagrywa duety - źle
2. Nagrywa "nowoczesną muzykę" - źle
3. Wraca do analogów - źle
Facet nagrywa niespodziankę dla fanów klasycznej elektroniki, to fani narzekają, że wariuje. O co Wam chodzi? Moim zdaniem gdyby nie nazwał tego albumu "Oxygene" wszyscy i tak mówiliby, że to kolejne Oxygene. Mamy 40-lecie i nie ma sensu udawać, że ten album nie był w karierze JMJ najważniejszy.
Ja się cieszę - bo wiem, że na pewno nie będzie to taka porażka jak Tubular Bells 3. Podejście z nagraniem całości za jednym podejściem w 6 tygodni jest super. Może płyta zyska dzięki temu "garażowy" czy nawet nieco "amatorski" klimat. Czyli odwrotność wycyzelowanych ostatnich "produkcji" JMJ. Może przynajmniej jeden kawałek będzie super. Na to liczę.
Przestańcie jęczeć. Nikt Wam nie karze niczego kupować. Posłuchamy sobie na Spotify i ocenimy.
K.
Post #113397 autor: Sublime » 03 paź 2016, 22:41
jman pisze:1. Nagrywa duety - źle
Wszystko to zgadza się, jeśli bierzemy pod uwagę płytki JMJ po 1997 roku. Tak, każda jego produkcja po Oxy7-13 to jakaś tragedia straszna. Nie wiadomo, do kogo to kierowane, czym właściwie inspirowane (jakieś sugestie?). Swoisty marketingowy new beginning, jak to sam Jarre mówił w okresie Metamorphoses.
Niewątpliwie, Oxygene 14-20 będzie niespodzianką dla fanów klasycznej elektroniki. Szkoda tylko, że niezbyt pozytywną i miłą. Co zresztą właściwie wspólnego ma Jarre z klasyczną elektroniką po tym nieszczęsnym 1997 roku?
Ostatnie "amatorskie" próby JMJ w takim stylu kończyły się czymś w stylu zwykłego hałasu, którego nie możemy nazwać muzyką (tlenowe wariacje) czy chociażby kradzieżą gotowych brzmień z jednego ze sprzętów Rolanda. Faktycznie, aż serce rośnie na kolejne nowości. :rofl:
Tylko tyle i aż tyle. Biorąc jednak pod uwagę takie, a nie inne słowa próbujące w jakimś sposób JMJ, nie sposób się do tego nie odnieść. Jeśli jednak ktoś lubi nabierać się na ten sam żart jak małe dziecko, to nikomu tego nie bronię.
musman76
Post #113399 autor: musman76 » 03 paź 2016, 23:43
Sublime pisze:Niewątpliwie, Oxygene 14-20 będzie niespodzianką dla fanów klasycznej elektroniki. Szkoda tylko, że niezbyt pozytywną i miłą.
Tego ostatniego nie wiemy na razie, dopiero gdy się ukaże.
A może... Czyżbym tak się zaczytał np., że nie zauważyłem, jak nastał grudzień? Bądź co bądź, fantastyka naukowa jest szczególnie predestynowana do przenoszenia człowieka w czasie. ;)
Post #113400 autor: PM7 » 04 paź 2016, 1:29
Ja się spodziewam czegoś na tym poziomie, jak jeszcze Jarre sprawdzi jakich progresji akordów użył w pierwszym Oxygene i czasami to zastosuje, to już będzie "dobrze":
https://www.youtube.com/watch?v=c71ucsKMYzE
jman
Post #113401 autor: jman » 04 paź 2016, 18:06
Czyli już słyszałeś? Ja i tak się cieszę. Przecież na tym polegał chyba główny zarzut wobec JMJ: brak "typowych" dla niego brzmień. No to właśnie otrzymamy to, czego nam brakowało.
O ile wiem - zrobił ponownie Oxygene, kilka wariacji i całą trasę z analogami na żywo. Mało? No to będziesz miał nową płytę z takimi brzmieniami.
K.
Post #113402 autor: Sublime » 04 paź 2016, 18:52
jman pisze:Czyli już słyszałeś? Ja i tak się cieszę. Przecież na tym polegał chyba główny zarzut wobec JMJ: brak "typowych" dla niego brzmień. No to właśnie otrzymamy to, czego nam brakowało.
Nic nie skłania mnie do takich pozytywnych wniosków. Jeśli ktoś wierzy w to, że Jarre jak za dotknięciem różdżki zacznie znowu z sensem gmerać przy analogowym sprzęcie i będzie w stanie brzmieniowo nawiązać do Oxy i Oxy7-13, to niewątpliwie jest człowiekiem wielkiej wiary. Nawet Oxy7-13 będące "wiernym" hołdem dla pierwszej części Tlenu ostatecznie wydaje się być bardziej brzmieniowo zbliżone do Equinoxe niż Oxygene. (choć oczywiście nie brakuje charakterystycznego Eminenta i Thereminu) Nie wspominając już o tym zdecydowanie szybszym rytmie płyty.
Zrobił to może za duże słowo, ale kolejna akcja generująca kolejny zysk na tym samym produkcie to odrobinę za mało, by uważać Jarre'a za wciąż aktywnego w nurcie progelektroniki.
Ostatnim autentycznie 100% muzycznym produktem wydaje się być utwór "Falling Down", który można skomentować jedynie pewnym pytaniem - co to ma być? Jeśli w tamtym okresie potrafił jeszcze nagrać w pełni analogową płytę w oparciu o klasykę to śmiało można by go nazwać cudotwórcą.
Choć ostatnio wydawnictwa JMJ zaczyna cechować już nie tylko słaba muzyka, ale i ewidentnie miażdżąca uszy postprodukcja i mastering. Tak jak pisałem wyżej, by wierzyć w dobre nowości spod rąk Jarre'a trzeba już chyba tylko mocno wierzyć. Albo zaklinać rzeczywistość.
Wróć do „Jean Michel Jarre”
